PEUGEOT 308 2012 1.6 90HP 68KW
frankieyeha
Got rid of most faults from before just 1 left p2565 fixed geometry turbo position measurement short circuit to positive or open circuit any ideas thanks in advance.
frankieyeha
Re: PEUGEOT 308 2012 1.6 90HP 68KW
The radiator fan is staying on I think the problem is there
PaulC5
- x 705
Use your code reader to look at live data to see if the engine temperature is showing as high. It could also be on if the exhaust dpf is being regenerated. Using the air con also puts the fan on when running the engine.
frankieyeha
The only code showing now is P2564 fixed geometry turbo position measurement.Short circuit to positive or open circuit.
frankieyeha
i defo think its the radiator fan relay gsf does one.
frankieyeha
CHANGED RELAY ITS STILL THE SAME.
