Xantia hydraulics
johnlyn
Xantia hydraulics
In the hope that somebody can help! I have a 1995 Xantia 1.9td that developed a leak at the rear off side K splitter, i had to cut all three pipes in order to remove as unions were rusted solid, the two 3.5mm pipes i have got ready to go back on the car the other a 4.5mm i believe to be the main feed, seems extra long as it loops over the top of the subframe, could i shorten the loop to make a new connection to the K piece? and does this pipe run the length of the car?
stephen burch
johnlyn
