2009 partner teepee 1.6hdi
Heater. Blower stopped working checked fuses. Powered Motor manually al? working. Nothing ?on speed control switch. Resistor replaced four months ago. Now not working again even on speed 4. Should there be power in the resistor plug coming into the resistor as thhere is not.. Could it be a fuse. I haven't located or someone's suggested faulty BSI module. Any advice please.
Peugeot partner teepee heater blower inop
- x 8121
Re: Peugeot partner teepee heater blower inop
The first thing to do is a proper BSI reset according to the following procedure. If you still have the problem then check the fuses in the engine compartment fuse box.: viewtopic.php?p=601679#p601679
PaulC5
- x 685
Some times the electrical connections in the wiring to the resistor and blower can burn out so something to look for.
terry margeson
Further investigation has revealed the heater relay is burnt out behind the glove box and the internal fuse board. Can anyone tell me the part number or type I need to buy please. The one I have taken out has no details on as to part number or brand. It is 5 pin 12v . I think the peugeot partner number is 6555vp but unable to locate one. Any help or advice would be appreciated.
- x 8121
