Not starting
Nashman1268
Not starting
Unread post by Nashman1268 »
Hi everyone hoping someone can point me in the right direction. 5008 1.5hdi headgasket went replaced the gasket. Car wouldn’t start then found out the timing chain had stretched, replaced the chain and cams. Still can’t get the car to start only fault codes coming up are starting monitoring anyone else had this issue
x 7831
Re: Not starting
Is your battery in tip top condition? :)
Nashman1268
Re: Not starting
Battery was fully charged nearly new
x 7831
Re: Not starting
I don't know I'm afraid but you may have to go into the ECU and tell it you have replaced the gasket and chain etc. Someone with better knowledge than me will see your post soon I hope! :)
x 1044
Re: Not starting
Unread post by wheeler »
Why was the gasket replaced in the first place?
Will it fire with a spray of easy start?
Nashman1268
Re: Not starting
Figured out the issue timing was out on the cams car now runs finally
