Nemo is knocking
ohspecial1
Nemo is knocking
Unread post by ohspecial1 »
Hi Folks
Wonder if anyone can help with knocking on Citroen nemo 2010 diesel
its not top mount noise
I'm guessing drive shaft seems like if i said under the dashboard
Any tips or things to look for
PaulC5
x 681
Re: Nemo is knocking
Unread post by PaulC5 »
Check the exhaust brackets in case one has rusted off the pipe - I have replaced a couple on a Cactus and one on a C3 using repair brackets from Autodoc that just clamp on. These gave a knocking noise and a check before looking underneath is to pull/push the tail pipe a bit to see if the noise is given.
