2012 Peugeot 308 SW 1.6 THP - 5FV
yotzee_
Unread post by yotzee_ »
Hello guys,
So i have a funny and sad story. I bought the car and took it to a mechanic with some strange noise from the engine. Then it turned out the mechanic guy lied to me all the time he tried to scam me... maybe he changed a lot of stuff as well but i cannot prove it so i am fckd...
I had to move the car with a trailer because the dashboard started to show water pump error stop immidiately etc.....
Those new guys changed everything but still not worked...
And i was going to an other country because of work so i leave the car at a third mechanic who said a lot of stuff is new and it should work now but the ecu is faulty....
He recommend i should buy a complete set ECU BSI keys...
And he just took out the ecu and gave it to my sister who take some picture and send it to me..
But again.. The first scammer guy maybe changed the ecu... Because I only found the same ecu for 508
I dont know I am confused and don't know what to do. The mechanic should make a diagbox report and it should reveil if it is an immo off donor, which he maybe did because he said it is original but again, my Sister manages this thing and she has no idea.. I think the guy was lazy to check these things...
Please someone who has a ServiceBox or have the same car tell me the correct numbers for this cars ecu. Please help [-o<
2012.10 Peugeot 308 SW 1.6 THP Active+ 156HP
5FV 048
The ecu from the car:
9666319580 1314 0018
11-08-24 1039S48153
0 261 S06 632
RB CMME MED174 CEM1
MED17.4.2
96 775 667 80
Thank you :cry:
x 8084
Re: 2012 Peugeot 308 SW 1.6 THP - 5FV
Unfortunately we don't have access to the Stellantis database at the moment so I cannot look it up for you. However another member with their own access may see your post and help you out. :)
