Electrical issue
craigypickle
Electrical issue
Hi all, first off I am very much not clued up on vans/cars so hoping someone can shed light to my situation. I have had an ongoing electrical issue with my 2019 Citroen dispatch. Various lights continue to pop up on the dashboard and are all red, the stop, battery and engine light. They will go away after a while but often come back on (sometimes the yellow spanner and yellow engine light). I have had my van at an auto electrician twice and 12 hours of work spent on it and they cannot figure out why they come on. They have advised to monitor the voltage (from a charger in the 12v plug) which normally hovers around the 14v mark. However this morning whilst driving it dipped down to 11.5 numerous times (noticeably slowing the window wipers) and went back up. I don’t know if they are related but recently it has had the flywheel replaced, the A/C motor ceased and snapped the alternator belt which has been fixed and I believe there was an adblue delete done before I bought it. Any help here would be appreciated. Thanks
- x 8134
Re: Electrical issue
You need to get a full diagnosis with Diagbox done and see what codes it throws up.
