Peugeot 2008 electric windows
deakin6
Both front windows stopped working. 2015 Peugeot 2008. Rears are manual. Where is fuse please and where next if fuse ok. Thanks
- x 8084
Re: Peugeot 2008 electric windows
You can find the answer to the fuse question on this link, it appears to be Fuse box 2 below the steering wheel and fuse number 3 in that box.
https://fuse-box.info/peugeot/peugeot-2 ... 2016-fuses
If the fuse is OK come back for more advice but since both windows have failed I suspect you have a blown fuse but that will have been caused by one window possibly sticking. If that was the case, spray the runner rubbers with a silicone lubricant before you test them after changing the fuse.
deakin6
30A fuse FO3 is fine. Any other suggestions please?
deakin6
Peugeot 2008 (65plate). Posted a while back re electric windows not working. Only front windows are electric, rears are manual. Fuse is ok. (F03) Does anyone know cable colour which brings power to drivers side window switch.so I can check cable and maybe run a temporary supply. Thanks
