crunching gears
espzetec
crunching gears
i sometimes find the gear change harch in my xantia. its only got 134k on the clock. I know the accululator sphere is knackered (ticks every 1 second its that bad!), so could this be anything do with the problem? ie poor opertaion of the clutch? i presumet he clutch is hydrolically controlled aswell as brakes? the brakes i know have been affected by the speher being rubbish.
uhn113x
- x 3
Your 'accululator sphere' has nowt to do with the clutch, but you should replace it (£20) before return pipes start blowing off and leaving your car sitting in a green puddle! [:(]
What do you mean by 'harch'? Does it go into reverse OK when standing? If not, does the clutch need adjusting?
If the gearchange is just stiff, have you tried lubricating the linkage?
Oh yes, what car are we talking about?
MW
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">the brakes i know have been affected by the speher being rubbish.
Fer cryin out loud, how many chances are you expecting to get to fix this?
espzetec
Jon
Your 1.9TD has a cable operated clutch.Its not hydraulic. Its possible to adjust it if your car is the before 1997 type, theres a 10mm and 13mm nut on the end of the cable at the gearbox. If adjustment does not help, maybe a new clutch is required.
I hope that you are going to change that accumulator ASAP. It sounds worrying!
espzetec
alan s
- RIP 2010
- x 6
Jon
espzetec
Jon
tomsheppard
jeremy
