2002 Xsara Picasso turning indicator tic-tac buzzer part number/location?
Problem: The 2002 Xsara Picasso turning indicator tic-tac buzzer nolonger works/sounds!
(This is also the same buzzer that sounds when you leave your light on after leaving the car).
I need to replace this, but even if I have passed days searching, I cannot find the part number for this part, nor the correct name for tis part.
And I do not find any helpful video on youtube or else where to show me where it is located, what it looks like, nor how to replace it.
Note; "Using AI" I did find the following part numbers. However on the internet and on the different car part sites - they find no reference to these numbers!
* 6566C1 (used on some Xsara/Xsara Picasso clusters and interior buzzers)
* 6566C2 / 6566.C2 (variation seen on parts lists)
* 6242A8 (less common — cross-referenced on some aftermarket listings)
In summary
1) Does anyone know the part number for this turning Indicator Tic-Tac buzzer?
2) Does anyone have a video link to how to locate and replace this turning Indicator buzzer?
Thanks in advance;
DMcC
- New User
- x 8064
Re: 2002 Xsara Picasso turning indicator tic-tac buzzer part number/location?
i think the part number may be 9653139280
- x 1056
From memory on models without COM2000 the little speaker in integrated into the instrument panel
on models with COM2000 the speaker is integrated into the actual COM2000 unit.
2002 is a changeover year so could be either, what is your VIN?
To operate the horn do you push on the steering wheel or is the horn button on the end of the lighting or wiper stalk?
