Peugeot Expert 2.0 Oil pressure
John1966
(Donor 2022)
x 4
Unread post by John1966 »
If it's not one thing it's another!!
My Peugeot Expert 2.0 2016 Mkii decided to flash up a low oil pressure warning this morning, very briefly after a cold start and then a few seconds later once moving.
Stopped, checked oil (only a few hundred miles and plenty in it) and restarted with no further warnings.
I'd been through a fair bit of water a couple of days ago... so electrical glitch from the pressure switch or is there anything more serious that I should be looking at
x 8086
Re: Peugeot Expert 2.0 Oil pressure
If you are happy with the level on the dipstick and the light has gone I'd motor on ignoring that. :)
John1966
(Donor 2022)
x 4
A quick update, happened again this morning so have investigated further.
Van has only done under 60K
An oil change didn't help, oil that came out was clean, no sludge or metal bits (it had only done around 1500 miles)
However when I disconnected the oil pressure switch there was oil in the connectors, so I'm hoping that that is the issue and new switch has been ordered.
