got a 2003 c5 mk1 2.0hdi al4 gearbox wet into limp mode pluged in lexi says oil pressure switch interminnet i double check with aWOW wurth diagnostic box says same thing is it possible oil pressure switch ....also were is the dam thing
ty
oil pressure switch
- x 8091
Re: oil pressure switch
You can download a free service manual from this site which will answer your questions: https://www.auto-manual.com/citroen/citroen-c5/
PaulC5
- x 677
According to the Haynes manual for the C5, the 2.0 hdi oil pressure switch is located above the oil filter on the SOHC engine and on the oil filter housing on the DOHC engine. Access might be easier from underneath with the undertray removed depending on the engine type.
