Tia
Morning 👋 anyone help with injector clamp settings??
Pietyboy
Morning all, I'm going to be replacing the seals on my 2021 Citroen relay 2.2bluehdi this morning and have ceramic grease and new bolts but conflicting info online about the torque settings for the injector clamps. Could anyone confirm the correct settings as really don't want to get it wrong, injectors were a pig to remove!!
Tia
Tia
- x 8133
Re: Morning 👋 anyone help with injector clamp settings??
If you make a donation to the forum using the button on the bottom left corner of the main banner at the top of the page it will give you authority to access the members area which has a vast amount of information. You will find details of the 2022 C5X7 2.2HDi torque settings etc at this link, which I assume will be the same for your Relay 2.2 HDi, once you have donated.:
https://frenchcarforum.co.uk/forum/view ... 25#p797725
