Anyone know if it is possible to remove the rain/light sensor from a breaking car and fit it to a car which didn't have that installed originally? I realise I will also need the steering wheel stalks but presume these can be unclipped somehow can they?
Tried removing one of these sensors from a Citroen but it appeared to be bonded solidly to the windscreen and not removeable in any way.
Remove Rain / Light sensor
PaulC5
- x 675
Arkis
- x 27
Re: Remove Rain / Light sensor
First of all, do you even have wiring preinstalled? If yes, it will be easy. Just some secondhand sensor (with NEW gelpad - it can't be reused because of contamination) and some basic coding/calibration.
If you don't have wiring, you will need wiring loom too, and most likely need advanced coding or even new BSI unit. I don't think that much hassle and money (BSI units and programmers are expensive) is worth it.
Citroen C4 Picasso 2013, 1.6 e-HDI 85kW, 6 speed manual
Peugeot 206, 2005, 1.4i 8v, 55kW, 4 speed AT
Peugeot 208, 2019, 1.2i PureTech, 61kW, 5 speed manual
Opel Insignia, 2015, 2.0 CDTi, 120 kW, 6 speed AT
Hyundai Santa FE 4WD, 2015, 2.2 CRDi 145 kW, 6 speed AT
NickCUK
- x 3
I was hoping that the wiring would be preinstalled much like the cruise control was where it was all there just not used, but don't know. Where do I look to check for the relevent plug to see if it is there? I can do the coding necessary with the Lexia-3, hope not to need a different BSI, can't see any evidence that Peugeot used different BSI for cars with/without automatic wipers.Arkis wrote: 18 Oct 2025, 17:29 First of all, do you even have wiring preinstalled? If yes, it will be easy. Just some secondhand sensor (with NEW gelpad - it can't be reused because of contamination) and some basic coding/calibration.
