non starter
mickeybo
non starter
c4 11 (b71) 1.6 8v hdif (dv62 (9hr) 2010-2012. There is no in tank fuel pump on this model can some 1 throw some light on this re-gards mickeybo
PaulC5
- x 697
Re: non starter
You need to provide more info.
Have you tried anything to fix a fault, did anything happen last time you used it, did the engine stop suddenly, when was the timing belt last replaced, any warning lights, is it turning over on the starter motor, is the key being recognised by the immobiliser (leave key in the ignition and open the driver's door - if recognised a warning will be given), have you had a diagnostic check ?
