Hello,
Error code P0299 Boost pressure too low appears more and more frequently - can be deleted - no engine warning light - no emergency mode.
According to the error, it should be the front turbo.
Does anyone know this error and/or is there any advice on how to fix this error on the C6 – is it perhaps just a leak in a part?
Many thanks in advance for any advice/help.
Regards, Wolfgang
Citroen C6 2.7 HDI - Error code P0299
cit-rotti
- x 78
Kees
- x 149
Re: Citroen C6 2.7 HDI - Error code P0299
It seems to me that the turbo is worn out.
PaulC5
- x 698
You could check if the MAP sensor (or other boost pressure sensor if it has one) is not bunged up with oil.
