Good morning,
I'm praying someone can help me.
I have had an error code pop up over the past week, for a dpf fault, error code P2452 to be exact. I am trying the cheapest options first, i.e Dpf cleaner/unblocked, but I have a feeling the dpf sensor needs replacing. I found a fairly cheap one online, but multiple attempts to locate it in the engine bay have failed. Would anyone happen to know where I can find it and if possible have a picture of the location, please? Thank you so much for your time.
C4 Cactus 1.6 Bluehdi 2016 / DPF P2452 Error
- x 1939
Re: C4 Cactus 1.6 Bluehdi 2016 / DPF P2452 Error
Welcome to the forum.
What do you mean by DPF sensor? The pressure differential sensor across the DPF? Or something else?
- x 1490
C4 Picasso, but the layout is probably similar, you need to get some live data, and check which code is actually present:
