Fuse allocation
tractionbrise
Fuse allocation
I have owned my Spacetourer Bluehdi150 for about a year. When I purchased it, the dealer replaced the battery and what they called the "battery control module" - could this be the battery management unit and protection (BMUP)? The car is in daily use and has thrown a couple of warning lights which have usually gone out. Recently, the car has been left standing for a few days, after which it fails to start. The dash displays the message "Energy economy mode activated". The voltage at the battery was 8v! When shut down a parasitic drain can be measured at 0.30 Ah but I am struggling to pin this down further due to a lack of a fuse allocation table. I can find one on the internet for the interior fusebox (which is mostly behind a birds nest of wiring loom). There is a 3rd fusebox behind the interior fusebox which can only be accessed by a tiny French mechanic with an endoscope. But I cannot find a fuse table that matches my engine compartment fusebox.
- x 8140
Re: Fuse allocation
I think this site should help: https://fuse-box.info/citroen/citroen-s ... 2018-fuses
tractionbrise
Re: Fuse allocation
Thanks Mick. That should be the one.....but isn't sadly. Does anyone have any alternative engine compartment fuse allocation tables for a 2018 Spacetourer? Mine is quite high spec, dual zone air con, sat nav that tries to drive you to a citroen dealer every time you hit a speed bump, electric arse warmers etc. etc.
- x 1469
Re: Fuse allocation
0.3A would not worry me too much when the car is 'awake', but it should be significantly lower when the car goes to sleep after a few minutes.
tractionbrise
Re: Fuse allocation
0.3 Ah is after about 20 mins when everything has shut down.
- x 1055
Re: Fuse allocation
Way to high then, shouldn't really be any more than 0.06A
Are you measuring this with all the doors & bonnet latched over & the vehicle locked?
If its a keyless model is the keys well away from the van?
tractionbrise
Re: Fuse allocation
Yup, everything shut, keys in the house. Also, failure to start after 3 days standing points to a parasitic drain. Battery is only 1 year old.
