Citroen Relay 2022 - 12v socket front/rear fuse locations
jamesroxby98
Unread post by jamesroxby98 »
Hi all,
My partner owns a Citroen Relay 2022 (L3) and neither the front or rear 12v sockets (cigarette lighters) work.
I have looked online for fuse box diagrams and have found this site: https://www.startmycar.com/gb/citroen/r ... fo/fusebox
However, the diagrams for the 2022 Relay do not match what I am seeing for our van. The above site states the 12v socket fuse is located in the engine bay fuse box but the fuse box which is located (very awkwardly) behind the passenger side headlight does not look anything like what is shown.
Please can someone advise the location of these fuses?
Many thanks,
x 8145
Re: Citroen Relay 2022 - 12v socket front/rear fuse locations
Can you post pictures of your fuse boxes and we may be able to help identify them. :)
x 1056
Unread post by wheeler »
Have you got a copy of the latest handbook for your van? It will have fuse diagrams/tables in it.
You can download them here> https://service.citroen.com/ACddb/index.html
As for the headlamp, it takes about a minute to remove the headlamp completely if its in the way.
