Hello everyone! I just bought DS7 crossback and as "winter is coming" I'm obliged to change tyres on my DS7 to winter spec. So I want to buy new wheels fitted with new tyres and so I was wondering about what sensors in them TPMS would work. Online, some sources suggest that DS7 has no sensor in tyre but uses tyre rotation to determine is it flat or not... others that 433mhz sensors would work.
any thoughts, word of advice?
Thanks in advance
Dario
Does DS7 Crossback from 2022 has TPMS senzors in tyre?
dario77
- x 8122
Re: Does DS7 Crossback from 2022 has TPMS senzors in tyre?
If you are buying new wheels then I would think the supplier will be able to advise you on which kit you will need.
joksa1984
- x 6
Hello,
If you have only information about pressure ok or not, and not exact pressure of each tyre in infotainment, than you have no sensors but only passive tyre rotation monitoring..
dario77
Will check it for sure in Infotainment, thank you all!
- x 1938
On our 308, which has indirect measurement, there is a menu option to reset the system after pumping the tyres to their correct pressures. It's in the "Driver Assistance" menu which, on our 308, is the second down of the four on the left of the screen. It's called Under-inflation initialisation.
