DS3 No Crank
PLUGSWOODY
DS3 No Crank
Unread post by PLUGSWOODY »
Where to start.
1.6 diesel 2013.
5mph turning into a carpark, vehicle died and no crank on key.
all electrics work apart from windows and indicators, radio(unless disconnect battery and reconnect) then they work.
esp light on , in eco mode.
checked obd terminals , usual ohms voltage etc. all within spec.
So i am looking for the canbus diagram which will show me the pin out for each module for the canbus and the order in which the modules are connected.
As my ecu and some other modules not showing up on my diagnostic tool or in diagbox iether.
have been searching high and low for days, but no joy, even purchased the ifix haynes online, and that didn't have any wiring diagrams.
Any one point me in the direction to get the diagrams or have then, would be most helpful.
thanks in advance :-D
x 8141
Re: DS3 No Crank
If you can post your RPO number from the label on the door pillar I will see if I can find any diagrams for you :)
PLUGSWOODY
Re: DS3 No Crank
mickthemaverick wrote: 01 Oct 2025, 16:33 If you can post your RPO number from the label on the door pillar I will see if I can find any diagrams for you :)
1329081 appreciated, thank you
x 8141
Re: DS3 No Crank
Unfortunately your car is just beyond the limited backup I have access to, so I cannot find a diagram. Hopefully a member with their own full access will see your post and help you out. Sorry! :)
PLUGSWOODY
Re: DS3 No Crank
Thanks for taking the time to look.
