Does anyone know if the door seals on later cars, say 5008, are a similar profile as used on the 307?
My 307 need new front door seals, can't use rear ones from the breakers because they are a couple of inches shorter. Got me thinking about whether I could use some rear door seals from a later car, which is likely to be generally larger door openings and therefore a bit longer, and cut them down to suit. That is if I can find any in the breakers yard.
Door seal rubbers
- x 8085
Re: Door seal rubbers
A call to these people may answer that for you: https://genuinemotors.co.uk/collections ... ther-seals
NickCUK
- x 3
Very helpful, thanks. Looks like they sell the same profile for all Peugeot models so I guess any will fit as long as length is enough.mickthemaverick wrote: 01 Oct 2025, 15:07 A call to these people may answer that for you: https://genuinemotors.co.uk/collections ... ther-seals
ozfrog
- (Donor 2026)
- x 76
They didn't solve the problem with our 306. I was hoping that they were going to be the saviour of our Cabriolet.mickthemaverick wrote: 01 Oct 2025, 15:07 A call to these people may answer that for you: https://genuinemotors.co.uk/collections ... ther-seals
Finding the front windscreen rubber surround is like finding a needle in a haystack.
Cheers,
Andrew
Andrew
NickCUK
- x 3
In the end found correct profile rubbers in the breakers yard off a 2-door 307 so will need to shorted the length. Stock Auto Breakers in Wickford, Essex who were very helpful.
