Hi all new to the group.
I’ve got a clutch pedal switch fault p0908 & want to try & check the wiring before replacing the master cylinder.
But struggling to find a wiring diagram.
It’s a 2014 1.6 diesel.
I did read somewhere that the 5v ref comes off the app ?
Can anyone point me in the right direction please.
C4 Picasso b78 wiring diagram needed
- x 8128
Re: C4 Picasso b78 wiring diagram needed
Unfortunately we do not currently have access to the Stellantis wiring diagram database but it is possible that a member with their own access will be able to help you out.
- x 1490
I think it's a position sensor rather than a switch. What does the error code say, and what dose the live data say? You could try unplugging it to see if the code goes permanent or to a different circuit code which will imply that the wiring is OK. The master cylinders on these are a know weak point...
