C5 X7 Breakdown
Camper Longflap
C5 X7 Breakdown
Unread post by Camper Longflap »
My car flashed an engine management light then a ESP warning then trundled to a halt on the M1 at Scotch Corner. (I live in Glasgow)
Anyway the RAC says its an injector issue, just wondered if anyone had encountered same and if it could be a DIY fix as I had to shell £500 to be towed home.
x 8149
Re: C5 X7 Breakdown
You need to get a high end diagnostic tool, ideally Diagbox, onto it and see what codes it throws up. If it is an injector then DIY is feasable as may an ECU be depending on your skill level. :)
x 2938
Re: C5 X7 Breakdown
Some of the AA and RAC guys can be rubbish at diagnosis, I once had a car towed in that had bad vibrations and been diagnosed as "Either a collapsed piston or the clutch has fallen apart." It was a broken fan blade, half of it had dropped off..
x 2004
Re: C5 X7 Breakdown
Unread post by Stickyfinger »
RAC = Needs a new alternator Sir
A new battery fixed it.........
