C5 X7 2.0L HDI Front NS wing
Estately
x 22
Unread post by Estately »
Part number.
Does anyone know if there is more than one front wing type for the C5X7.
I just found out the hard way that a new near side wing supplied for our 2013 C5X7 does not fit being a little too long.
The VIN is VF7**************[VIN obfuscated, can be read by forum staff] could you please let me have a part number.
Thanks in advance.
Andy.
If it can happen it will.
x 8127
Re: C5 X7 2.0L HDI Front NS wing
Unfortunately the forum has not got access to the Stellantis Database at the moment and the backup system I have does not use the VIN. I will see what I can find in a bit based on 2013 C5X7 2.0 HDI 160 but you may have to wait for a member with their own access to see your post and help you out. :)
x 8127
Here is all I have, I hope it helps! :)
C5 (X7) - 0610 07 743501A - FRONT WING.pdf
From Servicebox backup
(210.09 KiB) Downloaded 111 times
Estately
x 22
Thank you so much for the prompt response, that is at least what I thought I had bought.
It is new and fits round the headlight and bumper but is too long, overlapping the door and doesn't have the crease line, so I am not sure what it is, maybe a C6 wing.
Once trying to fit it the fastener holes do not line up.
The packaging had no part number on but it looked OK that is why an attempt to fit was made.
Thanks again.
Andy.
KennyW
x 165
Unread post by KennyW »
Was your 'new ' wing , new because when I did my wing it was new but not an exact match slightly long.Supposed to be insurance recommended !
It has to be either a new from Citroen ouch or 2nd from scrappy.
Kenny
C3 1.4 petrol (SWMBO)
