Citroen DS3 1.6 HDI quetions
joaocpereira
x 3
Unread post by joaocpereira »
Hello,
A friend recently bought a DS3, and while driving it, I noticed that the ambient light (under the radio in front of the gear lever) was flashing orange. What does that mean? I also noticed that the lights on the air conditioning controls only stay on when the air conditioning is on. Is this normal? Or is there a problem with the ambient light module? It has a touchscreen, and I looked to see if there was any ambient light function there, but I couldn't find anything.
Another question: on the headlights LED Is there only one reverse light?
I also noticed that one of the air conditioning ducts on the driver's side doesn't seem to open for cold air; only hot air comes out. Will I need to disassemble the dashboard to fix this?
x 8137
Re: Citroen DS3 1.6 TDI quetions
Are these questions serious? :(
joaocpereira
x 3
mickthemaverick wrote: 21 Sep 2025, 18:50 Are these questions serious? :(
Yes why? Is not a forum? To discuss and put questions? ...
x 1466
Re: Citroen DS3 1.6 HDI quetions
Unread post by xantia_v6 »
Your first post is a little confusing. Can you clarify the question about the headlights LED?
It is normal that the A/C panel is only illuminated when switched on.
A problem with temperature control on one side can be due to a broken flap or control motor.
