Low beam faulty
Millsy56
Low beam faulty
I have had a problem with the near side low beam being delayed and then flashing a few times before coming on whereas the driver side always came on immediately but now it wont come on at all ,the high beam comes on but not the low beam ,same bulb , I have changed the bulb , fitted a new relay, checked the wiring and connections close to the headlamp itself. Any ideas anyone?
- x 8128
Re: Low beam faulty
What year and exact trim level is your car?
- x 8128
Re: Low beam faulty
In which case I'm afraid I cannot help, I only have access to models up to 2013. Hopefully someone with full access to the Stellantis database will be able to find the wiring diagram for you.
Millsy56
Re: Low beam faulty
Thank you for your help anyway.
