Reversing camera error after replacing SMEG+ with NAC
This is the Connected NAV system.
Main Features: It is a fully integrated Telematics System featuring CarPlay, Android Auto, Real Time Services, Voice Commands, High-Res Display, 3D Navigation, Bluetooth Hands Free & USB. 2 versions of the system are available NAC (Navigation Audio Connectée) and RCC (Radio Couleur Connectée) or Connected Colour Radio, which does not have the Integrated Navigation or Live Services.
alinnita
Unread post by alinnita »
Hello everyone
I recently replaced the SMEG+ unit with an original NAC one. After the replacement I had a beep every 2 seconds and later I went to the Peugeot representative to change the VIN. After changing the VIN series I noticed that the rear view camera was no longer working. Going to them again for a solution they still haven't found a solution. Has anyone else had this happen? Should I consider updating the firmware? I mention that I have version 21.07.67.32_NAC-r0.
Thank you
x 1942
Re: Reversing camera error after replacing SMEG+ with NAC
Unread post by Paul-R »
Did the camera stop working after the NAC was fitted or did it work until the VIN was changed?
alinnita
It worked until he changed the VIN
Thank you
