Hello all,
I`ve replaced my BSI with a virginized on on my 307 2.0 hdi from 2007
After figguring all the options and making it work via Diagbox I can't figure out whats wrong with dashboard lighting
When i turn the headlamps on the interrior lighting goes in to dimming loop, the car is equipped with both rain and brighness sensors but every option that I set regarding this via diagbox produces same result
Does anyone have an idea whats wrong or how to fix ?
Replaced BSI Light Dimming goes into loop
- x 8084
Re: Replaced BSI Light Dimming goes into loop
It is fairly usual for dash lights to be dimmed when you turn on the cars lights, so I'm not sure you have a fault
vuk88
It goes into loop and changes the dimming all the time
- x 1056
Why was the BSI replaced in the first place?
Are you able to read the configuration off the old one? Has to be a configuration issue surely
