Thinking a strange one.
Geting engine fault light coming on.
Fault codes are.
p1349 fuel level sensor B circuit high (citroen)
p2562 turbocharger boost control position sensor A circuit (generic)
There is no noticeable difference in driving/engine running.
Reset codes.
Had thought about it being the Turbo Boost Pressure Solenoid Valve or Turbo Boost Position Sensor as that is what code p2562 points to.
but there is no performance issue.
So now thinking it is the fuel gauge ( the citroen code) as it seems to come on when fuel level reaches a certain point (one bar below half) i think? the other code being a red herring.
most issues i have seen are the gauge not indicating at all.
continuing research as i generally fill up about 1/2 a tank weekly. now watching that gauge with care. 1/2 full now. expecting to see it soon. then will put a £5 in the tank to test it again.
fuel level sensor fault.
- x 8128
Re: fuel level sensor fault.
What model and engine are you referring to?
livewire101
its a c3 picasso 2012 1.6 Diesel
DV6DTED
DV6DTED
