Engine management says ecu
Dannyc84
Unread post by Dannyc84 »
Hi I’m just wondering if any has had these issues I have a Citroen nemo 1399cc 58 plate and the engine management light is on and someone plugged in and said an ECU fault
Is it common ?
Easy fix ish ? 😊
And any advice would be great
Thanks Dan
Huskyxantia
x 920
Re: Engine management says ecu
Unread post by Huskyxantia »
Try clearing the faults , then check the ecu for any signs of corrosion on the socket pins and if so give it a blast with contact cleaner also check the looms for any signs of fraying or exposed wire.
:-D
PaulC5
x 697
Unread post by PaulC5 »
Can you put the fault code on here, it will enable us to provide more specific help.
