Citroen C5 2012 2.2HDI automatic
Ben C5
Unread post by Ben C5 »
I have this car since 2023, it had 205000 km now it has 295000. It runs very good except one little thing.
When driving uphill and I have to stop, sometimes when I release the brakes the car moves backwards. I am used to it now, so I don't release the brake until I am sure it will not do that.
I was at the local dealership service, and tried a couple of Citroen service shops, but they can't find the fault.
x 8144
Re: Citroen C5 2012 2.2HDI automatic
That sounds like a lazy sensor type problem, can you get it scanned for fault codes?
Ben C5
every time I send the car to a workshop they suspect it's a automatic transmission problem, but the transmission doesn't give any faults.
I will send it to check for sensor faults.
thanks
Ben C5
mickthemaverick wrote: 09 Sep 2025, 13:40 That sounds like a lazy sensor type problem, can you get it scanned for fault codes?
The fault is U1213 - Permanent fault - Vehicle speed information incorrect value received
