xantia 2.1td
brianr.uk
xantia 2.1td
i am thinking of changing my 1993 xantia 1.9td for a 1998 2.1td can anyone tell me if there is anything i should look out for.thanks in advance .Brian
JohnD
- x 72
I've run a 1998 2.1 Xantia estate for six years and it's a great car. Pre-purhase checks need be no more than what you would do on any other Xantia. Leaking rear doors and dropped front doors have been reported on this forum, although, fortunately I haven't noticed either fault on my car. Maintenance is similar to any other XUD. Replacement of glowplugs require a bit more dismantling. And replacing of the cambelt needs the top engine mount bracket removing from the inner wing. The clutch is a sealed for life hydraulic system.
NiSk
