vin lookup
livewire101
vin lookup
Unread post by livewire101 »
hello.
could i get the spec sheet please.
THANK YOU.
x 1472
Re: vin lookup
Unread post by xantia_v6 »
Sorry, we don't currently have access to the Stellantis data base. Maybe a member who does have access can help you.
x 1056
Re: vin lookup
Unread post by wheeler »
Here you go
Vehicle characteristics
Vehicle family C3 PICASSO
AS/RP N° 13031 76 1 0049
Warranty Start Date 17/09/2012
Engine serial number 10 JBEJ 3060179
OPB E008
BER e2*2001/116*0371*16
P4A 9802314899
General information
PRODUCT TYPE PASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPE CITROEN
VEHICLE FAMILY C3 PICASSO
SILHOUETTE FAMILY SALOON
TRIM LEVEL HIGH MEDIUM
ENGINE TURBO DIESEL DV6DTED
TRANSMISSION LONG 5-SPEED MANUAL GEARBOX
PAINT TYPE METALLIC PAINTWORK
BODY COLOUR KGW - BELLE-ILE BLUE PAINT
INTERIOR TRIM TYPE WARP AND WEFT BRISE+OMNI REPS "6D"
UPHOLSTERY COLOUR "FX"
GEARBOX (CHARACTERISTICS) BE4-5L MANUAL GEARBOX
DEFINITION TO FOLLOW INITIALE RANGE
ENGINE (TYPE) DV TYPE ENGINE
OTHER BADGE, " MISC. " EXCLUSIVE
BADGE FAMILY BADGE
STEERING POWER STEERING
SPEEDOMETER DRIVE W/O TACHO TORQUE
Fuel supply-Engine
FUEL SUPPLY DIRECT EXCHANGER TURBO INJECTION
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
FUEL DIESEL GRADE DA/DE/DE+
EMISSIONS STANDARD (ENGINE) EURO 5 L6 UPPER ENGINE EMISSION CONTROL
CAPACITY 1600 CM3
CATALYTIC CONVERTER 2 FILTERING COMPONENTS IMPREGNATED WITH PLATINUM+PADIUM 40G
REAR IMPACTS STANDARD RR BUMPER
FUEL TANK FUEL TANK WITH LOCATING TAB
OPTIMISATION OF VEHICLE’S CONSUMPTION OPTIMISED FUEL CONSUMPTION
COOLING MOTOR RADIATOR TH : 18 - 21 DM2 BRAZED ALUMINIUM
CRANKCASE GAS CIRCUIT HEATING WITH HEATER CASING GAS CIRCUIT
POWER VARIATION (ENGINE) POWER 68 KW 230 NM
EOBD SELF-DIAGNOSIS SYSTEM "EOBD" AUTO-DIAGNOSTIC WITHOUT ACCELEROMETER
DEVICE (ANTIPOLLUTION) "EGR" EXHAUST GAS RECYCLING
VEHICLE TECHNICAL DEPOLLUTION TECHNICAL VEHICLE EMISSION CONTROL EURO 5
PARTICLE FILTER WITH PARTICLE EMISSION FILTER
FAN 1 AERO 2-SPEED 140W FAN WITH SCOOP
FUEL VAPOUR RETRIEVAL WITHOUT PETROL VAPOUR RECUPERATION
INJECTION ASSOCIATED VARIANT MOUNTING BOSCH
TANK FILTER CITHOUT RESERVOIR FILTER
STOP AND START WITHOUT STOP AND START
Gearbox Transmission
FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 17 X 61
WHEEL STYLE 16 INCH BLADE WHEEL
SEAL, WHEEL END WHEEL-SIDE SEAL RZ 17.5
SEAL, DIFFERENTIAL END AXLE-SIDE SEAL JB2T
DIFFERENTIAL (GEARBOX) DIFFERENTIAL 84
RIM/TYRE SIZE 16 INCH TYRE FITMENT
TYRE (SIZE, TYPE) 195/55 R16 91T REINFORCED TYRE
WHEELS FITTED 6" RIM ROAD WHEELS
WHEEL (TYPE) ALLOY WHEEL ASSEMBLY 1
GEARBOX TYPE GEARBOX BE4R
Suspension-Steering-Brakes
ABS WITH ABS BRAKES
REAR ANTI-ROLL BAR WITHOUT REAR ANTI-ROLL BAR
FRONT ANTI-ROLL BAR FRONT ANTI-ROLL BAR DIAM 23
SUSPENSION NORMAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEM WITHOUT ELECTRONIC STABILITY PROGRAM
BRAKE ASSOCIATED VARIANT ABS TEVES MK100A
STEERING (OPERATION) ELECTRIC POWER STEERING
PEDAL BRACKET (TYPE) SIMPLE STANDARD PEDAL BRACKET
Body fittings
TOWBAR TOWBAR
HORNS HORN STANDARD
AERIAL SHORT ROOF AERIAL
PAYLOAD NORMAL PAYLOAD
FINISHER (SELF-ADHESIVE) GLOSS BLACK REAR SURROUND TRIM
SIDE MOULDINGS (TYPE) SIDE TRIM BODY COLOURED + CHROME
SIDE MOULDINGS (DIMENSION) THIN SIDE PROTECTORS
WHEEL EMBELLISHER (STYLE) WITHOUT WHEEL CAP
UNDERBODY SHIELD PLAST+FOAM UNDER ENGINE PROTECT+OPTIMISED REAR
INDICATORS WITHOUT SIGNALING LIGHTS
EXT. LOAD RETENTION RING (ATTACHMENT) WITH DETACHABLE EXTERIOR LASHING RING
EXT. REARVIEW MIRROR COMP. FUNCTION ELECTRIC FOLDING EXTERIOR MIRROR
EXHAUST TAILPIPE TRIM W/O EXHAUST OUTLET EMBELLISHER
ENGINE BAY SOUNDPROOFING BONNET SOUNDPROOFING
WINDSCREEN WIPER FRONT WIPER BLADE WITH RAIN SENSOR
FRONT PANEL BLANK FRONT FACE LOWER CLOSER
ROOF GLASS WITHOUT ROOF WINDOW
BUMPER FR + REAR BUMPER STD BC + CHROME TRIM
MUDFLAP MUDGUARD FR + RR
LUGGAGE RACK MOUNTING WITH ROOF BARS
FRONT FOGLAMP FRONT FOG LIGHTS
SPARE WHEEL WITHOUT SPARE WHEEL
EXTERIOR ACCESSORIES PAI/CHRO EXT HANDLES + BOD COL/CHRO NUM PLATE TRIM
BODY CONVERSION WITHOUT
BODY PROTECTION WITHOUT
BUMPER TRIM BODY COLOUR BUMPER STRIP
GLASS (APPEARANCE) TINTED + DARK-TINTED WINDOW GLASS
Interior fittings
ANTI-THEFT ALARM WITHOUT THEFT PROTECTION ALARM
CIGAR LIGHTER WITHOUT CIGAR-LIGHTER
REAR HEAD RESTRAINT REAR HEADREST ADJUSTABLE
REAR SEAT ARMREST WITH REAR SEAT ARMREST
LUGGAGE COVER SHELF
REAR SEATBELT REAR 3-POINT 3 INERTIA REEL SEAT BELT
FRONT SEATBELT DOUBLE PYROTECHNIC SEAT BELT WITH ALARM
ASHTRAY FRONT ASHTRY
CLIMATE (AMBIENT TEMP) TEMPERATE COUNTRIES
AIR CONDITIONING AIR CONDITIONING WITH CONTROLLED AIR INTAKE
CHILD LOCK ELECTRIC REAR CHILD LOCK
SPEED GRADUATIONS SPEED GRADUATION IN MPH
GRAB HANDLES PASS FR HANDLE + REAR + HOOK
RADIO EQUIPMENT SUPPLY FOR RECEIVER AERIAL FR/RR SPEAKERS
DRIVING POSITION RIGHT HAND DRIVE
ADDITIONAL HEATING WITHOUT ADDITIONNAL HEATING
LOAD SPACE LIGHTING WITHOUT ARRANGING LIGHTING
BOOT AND LOAD SPACE LIGHTING BOOT + LOAD SPACE + AMV LIGHTING AUTO CONTROL
DASHBOARD EQUIPMENT "SOFT" PAINT EFFECT DASHBOARD EQUIPMENT
MISC. INT. LAMPS FRONT MAP READING LIGHT
WORK TABLE WITH WORK TABLE
LOAD SPACE TRIM CARPET BOOT MAT+CARPET SIDES
UNDERSEAT STORAGE 1 UNDER SEAT STORAGE DRAWER
CHILD SEAT ANCHORING POINTS WITHOUT CHILD SEAT MOUNTING WITH ISO RR
LOUDSPEAKER ASSEMBLY 2 FR SPEAKERS + 2 RR SPEAKERS
RADIO CONTROLS REMOTE RADIO CONTROL
FRONT PASSENGER SEAT FOLDING FRONT SEAT FULL UPRIGHT FOLDING
FRONT SEAT ARMREST FRONT SEAT CENTRAL ARMREST
COMPACT DISC WITHOUT COMPACT DISC
STOWAGE BIN FLAPS IN FLOOR
SATELLITE NAVIGATION SYSTEM WITHOUT NAVIGATION SYSTEM
REAR WINDOW LIFT ELECT CONTR RR WINDOW LIFTER + LOCK SYSTEM
DRIVER’S WINDOW LIFT SEQUENTIAL DRIVER’S ELECTRIC WINDOW
PASSENGER’S WINDOW LIFT SEQUEN CONTROL PASSENG FRONT WINDOW LIFTER
DISPLAY DISPLAY (RADIO+CLOCK,T°,CD)
OIL GAUGE STD OIL LEVEL INDICATOR
FITTING REAR HEAD RESTRAINT MOUNT 3 REAR HEAD-REST
HEATING ELEMENT NON HEATED SEAT
FRONT LATERAL AIRBAG THORAX SIDE + CURTAIN AIRBAG
FOOTWELL LIGHTING DRIVER’S + FRONT PASS’S FOOTWELL LIGHTING
PASSENGER AIRBAG WITH AIRBAG ON PASSENGER SIDE
EQUIPMENT PACK W/O EQUIPMENT PACK
EXTERIOR REAR VIEW MIRROR (HEATED) HEATED DOOR MIRROR
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
INTERIOR DOOR CONTROL (APPEARANCE) CHROME EFFECT DOOR HANDLE + COLOURED TRIM
STORAGE (DRIVING POSITION) CENTRAL STORAGE COMP + LOWER STORAGE COMP
RADIO RECEIVER AUDIO CD SYSTEM RDS "RD45" MP3
REFRIGERATION AUTOMATIC AIR CONDITIONING
CRUISE CONTROL REGULATOR AND SPEED LIMIT
INTERIOR REAR VIEW MIRROR DAY -NIGHT INNER REAR MIRROR
STORAGE (OTHERS) PLAIN STORAGE POCKET
CARPET COVER W/O CARPETMAT
DRIVER AIRBAG DRIVERS AIR BAG
LOAD SPACE STORAGE WITH BOOT TIDY
TUNER RADIO MONO RADIO TUNER
OBSTACLE DETECTION SYSTEM REAR RADAR OBSTACLE SENSOR
LATERAL BLINDS SIDE BLINDS "ROW 2"
TRIM ADAPTATION G/LEVER KNOB LEATHER CHROME INSERT
FLOOR MAT W/O CARPETMAT
RADIO FREQUENCY WESTERN EUROPE RADIO FREQUENCY
LOCKING CONTROL CENTRAL DEAD LOCKING
STEERING WHEEL LEATHER STEERINGWHEEL
DRIVER’S KNEE AIRBAG WITHOUT DRIVER’S KNEE AIRBAG
CHILD OBSERVATION INTERIOR MIRROR INTERIOR CHILD MONITORING MIRROR
AUDIO PACK AUXILIARY SOCKET 1 JACK SOCKET + USB
TELEMATIC UNIT WITHOUT TELEMATIC UNIT
Electrical
ALTERNATOR ALTERNATOR 150 AMP
HORNS HORN STANDARD
BATTERY BATTERY L2 640 60AH EF 640 EN
STARTER MOTOR STARTER MOTOR CL 4
SPECIAL LIGHTING AUTOMATIC HEADLAMP ILLUMINATION
CEN. LOCKING REM CONTROL FREQUENCY 433.92 MHZ SUPER HETERODYNE
BATTERY CHARGE MEASUREMENT WITH BATTERY CHARGE MEASUREMENT
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION STANDARD
MODIF. DURING MODEL YEAR WITHOUT MINOR MODIFICATIONS
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
VIN PLATE EUROPEAN UNION CONSTRUCTOR’S PLATE + NRE
LABEL WITHOUT LABEL
RADIO HEADPHONE SOCKET DOUBLE ACCESSORY SOCKET
TRAFFIC SIDE DRIVING ON THE LEFT-HAND SIDE
SET OF KEYS 2 HIGH FREQUENCY REMOTE CONTROL KEYS
DOOR SEAL SEAL DIRT EXCLUDER
REFRIGERANT WITHOUT REFRIGERANT LIQUID
EMERGENCY EQUIPMENT PUNCTURE REPAIR KIT
SLAVE CONTROL UNIT BSI + COM 2005
EMERGENCY WARNING TRIANGLE WITHOUT WARNING TRIANGLE
