2019 peugeot expert central locking fault
Sojm216
Unread post by Sojm216 »
Not sure if anyone has come across this fault before. 2019 Peugeot expert central locking will lock all doors with the transponder fine. However it only unlocks the ns sliding door with the transponder. All other doors need to ge opened with the key in each lock. I have checked all fuses and selective door locking options all OK. Would anybody know any common problem areas to check?
Thanks 👍
x 1066
Re: 2019 peugeot expert central locking fault
Unread post by Rp0thejester »
I've had similar with my C8 and it's normally due to engine being shut off if electric sliding door is open after the countdown. I would suggest a battery reset with all doors closed.
Sojm216
Thanks for your reply . I have disconnected the battery overnight not sure if this is the same as a battery reset? Thanks for your help
x 1066
There was a reset procedure on the forum but cannot find it, hopefully a mod can send you the link.
x 1938
Unread post by Paul-R »
Sojm216
Thanks I will try this method tomorrow
hamid28shah
Unread post by hamid28shah »
Good evening,
I have the exact same issue with a partner. Did you manage it fix the issue? Thanks
