Hello all.
Looking for advice.
My father's Peugeot 308 has an issue with indicator not returning to it's original position. I think it was right turn. Left works fine. They took it apart in garage and didn't look anything wrong with the indicator switch itself. So advised to change the whole combination switch (squib). With all 4 switches around the wheel. Apparently too much hassle to try to fix the indicator switch on it's own.
Unfortunately the part is well expensive new and not easy to find second hand.
So I'm hoping someone can help with part numbers. Original part number is 96659951XT. I have seen many other part numbers for the same model but not sure if any of them fits.
Peugeot 308, 2009, 1.6 HDI, 90 or 92 horses, hatchback, manual. 4 switches on steering wheel.
Thanks in advance if anyone can help.
Combination Switch
- x 8084
Re: Combination Switch
Is this the switch set you are after? https://www.ebay.co.uk/itm/397002328836 ... R9D3jdWiZg
Rray
That's the one mickthemaverick but oursnhas got code 96659951XT
- x 1485
There are myriad versions of these, you need to find one that has the same number on it as yours. You could end up chasing your tail with all sorts of odd behaviour if you fit a different one.
PaulC5
- x 675
Out of interest, how much is a new one ? Could you get a really cheap used one with any old number and just swap the damaged part over if they are the same ?
