X7 Oil Seals dimensions
reshangv
Unread post by reshangv »
Hi Team,
Greetings from Mauritius Island. I currently drive a 2012 2.0HDi X7 with the DW10CTED4 engine.
Will be going through to change the timing belt soon and I wish to change the camshaft and crankshaft oil seal. Also required to change the driveshaft seals as they are leaking.
So far I have found the shaft seal to be ID: 40 | OD: 58. However this needs to be confirmed.
Can anyone provide the inner and outer diameter for these seals so I can order them.
x 8142
Re: X7 Oil Seals dimensions
Hi and Welcome to the FCF
Unfortunately we are currently and hopefully temporarily, without access to the Stellantis Database so I cannot source the information for you. However hopefully another member with their own access may see your request and help you out. :)
PaulC5
x 698
Unread post by PaulC5 »
If you buy them from a Citroen dealer they will supply the correct seals.
shtu
x 78
Unread post by shtu »
I've no idea what parts supply is like in Mauritius, but I'd be tempted to hit the parts catalogues for Elring\Victor Reinz\Corteco and use your engine and gearbox code to find the correct items, then shop from there.
I picked a random-ish C5 2.0 diesel, and for example, if your engine code is RHA or RHF,
the front crank seal is an Elring 107.130
the camshaft seal is an Elring 153.740
You can find references for the driveshaft seals too.
NOTE - This is an example - use YOUR specific details
https://web.tecalliance.net/elring/en/p ... mber:31997
From there, find a supplier that will also crossreference them for you and confirm it's the right part. I do that as then the supplier is on the hook for any "wrong part" returns.
Steve Walsh
x 518
Unread post by Steve Walsh »
Any good seal supplier should be able to suppy, Try taking them out, they probably have the size embossed on them. I have never paid anything like the Elring prices
shtu
x 78
I don't think they're too badly priced myself. :)
https://www.motor-doctor.co.uk/products ... shaft-seal
OP, Note all the handy cross-references to other brands on that list. You can do that quite easily for your specific part, then find something available local to you.
Steve Walsh
x 518
What a Di***ead I am, I read the Elring number as a price........Sorry.
