2015 C4 Timing Belt
DHallworth
x 161
2015 C4 Timing Belt
Unread post by DHallworth »
Evening all :)
My wife's Citroen C4 is due for a timing belt and water pump change.
I believe it's a Blue HDI but am not sure if it's a 1.5 or 1.6 engine that's in it. The VIN is VF7**************[VIN obfuscated, can be read by forum staff].
Does anybody know the engine specs?
I've seen a couple of timing belt and water pump kits but am not sure of the correct part number for that car.
Also, does anybody know where I might find the instructions for doing the job too?
Many thanks,
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
x 8142
Re: 2015 C4 Timing Belt
Hopefully this video will show you how David, but I'm afraid we are still without Stellantis database access to get your specs. :)
x 1941
Unread post by Paul-R »
2015 is too early for the 1.5 engine. So you'll have the 1.6 BlueHdi, same as our 308.
PaulC5
x 698
Unread post by PaulC5 »
To get the right parts for your car you might be best to visit a dealer and use your vin. Note that pattern parts may have a different replacement interval to Citroen ones. Whilst there also get them to give you a quote for the job to see how much you will save by doing it yourself. For our Cactus in December 2023 the timing belt/tensioner/pulley/water pump/coolant were £267 at the dealer but with fitting plus an aux belt/tensioner it was £780.
DHallworth
x 161
Citroen have closed all our local dealers now so going to see them is a pain. It’s a huge factor as to why this will be our last PSA car as well. :(
Their fixed price service offer for the belt and water pump on the C4 is £759. If genuine parts cost half of that I’ll be going aftermarket as it’s only a belt, 1 idler and a tensioner. I always try and stick to genuine but the price of parts these days is going wild.
Typically, as this is due a timing belt it’s developed a rattle that I believe only a drop link thankfully and a TPMS fault. All before it’s due an MOT at the start of Oct. :roll:
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
x 1496
Put an SKF kit on my 3008 last year - their website has a selector so you can find the kit number - then look elsewhere to get it cheaper! Other brands will no doubt be the same. No point in paying dealer prices for a belt kit, they just re box one of the brand names anyway. It's a straight forward job as cambelts go.
DHallworth
x 161
Thanks Richard, found an SKF kit on eBay for £86 so I'll get that ordered up.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
