I have a engine fault light.
codes
p1349 (Citroen) Fuel level sensor B circuit high.
And
p2562 (Generic) Turbocharger boost control position sensor A circuit.
Car seems to run fine, as normal.
reset fault and it has now came on 3 times after doing well over 100 miles each time.
Confused about the fuel level one as the fuel gauge works?
and boost control issue seems to result in rough running. Which i have none.
A search would indicate a fault with the "Boost Pressure Solenoid Valve" 0r "actuator position sensor"
May try and replace these as they dont look too expensive.
would appreciate if any one could give me the correct part numbers.
VIN. VF7**************[VIN obfuscated, can be read by forum staff]
Thank you.
fault codes p1349 and p2562 on a C3 picasso 2012 1.6 hdi
livewire101
- x 8130
Re: fault codes p1349 and p2562 on a C3 picasso 2012 1.6 hdi
Unfortunately the forum is without access to the Stellantis database at the moment but hopefully a member may be able to help out.
