5008 mk1 error codes
amazighman
Unread post by amazighman »
Hi.
Scanned my 2011 .2.0 hdi with Icarsoft and came up with 3 error codes.
P2297 oxygen sensor heating, resistance of the heating circuit outside range.
Which o2 sensor , upstream or downstream?
Car stalls after startup and driving off occasionally ,so it came up with two fuel pressure faults.
P2291 rise in pressure in injection rail too slow on starting
P0087 pressure measured in injection rail is lower than setting.
Any ideas
Regards
x 8085
Re: 5008 mk1 error codes
I think you'll find the answer to your first query here: https://carmodnerd.com/p2297/ :)
amazighman
Thanks.
My reader isn't specific its it o2 sensor before or after CAT
amazighman
Think it only has 1 o2 sensor right?
