309 Thingie
Davewall
309 Thingie
Unread post by Davewall »
I`m just fitting a S/H towbar to my old 309 (1.3 petrol)
Clipped onto the rear crossmemeber is a black thingie with a pipe attatched. It is about 1.5" long and similar diameter, the pipe runs up the wheel arch.
Is this the tank breather??
Just wanted to know if its position is critical as it is in a place where the towbar needs to fit.
Dave
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
Hi Dave - My experience is confined to 205s and BXs but what you are probably looking at is a vent valve for the fuel system. If it's in the way of your towbar fitting I would think it could be moved slightly.
Davewall
Thanks John,
I`ve moved it a few inches at the same level.
Dave
NiSk
Unread post by NiSk »
I'm pretty sure that its the overflow pipe for the tank filling recess (the one that leads away petrol if you get over enthusiatic and try to top off the tank to much).
So it won't matter if you move it a bit.
//NiSk
