C4 B7 EGS clutch issues
Bauke
Unread post by Bauke »
Good evening
I have removed the transmission and replaced clutch disc, pressure plate and clutch thrust bearing slave cylinder assembly
The problem I'm having is when I try to depressurise system or bleed system or try and program the clutch it always fails, programming of the gear selection works fine
Does anyone have any great ideas or knows how to rest trans eco to start again from scratch
x 8124
Re: C4 B7 EGS clutch issues
If you post up your VIN which will be masked from public view you have a better chance of getting some advice, :)
x 1490
Did you fit the correct EGS clutch (it's not the same as the manual one seemingly)? Are you using an external power supply when you try the programming? Are there any fault codes showing?
Bauke
Yes correct clutch and a power supply on battery when programming
Robcham
Unread post by Robcham »
Did you get sorted. I have the same issue
