Peugeot 208 1.4 Vti engine fuse box
Daniel78
Unread post by Daniel78 »
Hello colleagues.
It seems that my car has a temporary short circuit, which occasionally causes an engine overheating alarm on the dashboard.
(The engine does not actually overheat. The diagnostics can continuously measure the temperature).
I found a blown fuse (F9) in the engine fuse box, but I'm not sure what its function is, because the diagrams I found on the internet and forums are all different.
Does anyone know what the function of the F9 fuse is?
Is there a wiring diagram for the engine fuse box for my car (P208 1.4Vti 2012) somewhere? Or where should I look for it?
x 8085
Re: Peugeot 208 1.4 Vti engine fuse box
You may get some help from this site: https://fusecheck.com/peugeot/peugeot-2 ... se-diagram :)
Failing that, this one suggests F9 is for the front heated seats https://fuses.guru/peugeot/peugeot-208- ... ompartment
PaulC5
x 675
Unread post by PaulC5 »
There is usually a fuse list in the handbook, have you looked there ? If you do not have the handbook you can see it through this topic viewtopic.php?t=63209 although a quick look on p168 does not show a fuse at F9 so may be an optional accessory.
What amp rating is the fuse that has failed ?
We had a 2010 C3 with the 1.4 vti and that sometimes gave a false overheating alarm and it turned out it was a known fault and Citroen had a recall fix if you complained. It involved fitting a new temperature sensor with a short wiring loom on the thermostat housing. The sensor was installed at the air bleed point and the old one left in place but not connected.
x 1450
Unread post by xantia_v6 »
According to the best information I have, assuming that your engine is an EP3C, F9 is an engine ECU fuse (15A) and only feeds the engine ECU (pin6).
Daniel78
mickthemaverick wrote: 23 Aug 2025, 15:12 You may get some help from this site: https://fusecheck.com/peugeot/peugeot-2 ... se-diagram :)
Thank you for the advice, but unfortunately all the pictures&infos come from the original Owner's manual. This manual doesn't mention that fuse.
It is an 15A mini fuse and appears to power the ECU.
Daniel78
xantia_v6 wrote: 23 Aug 2025, 19:21 According to the best information I have, assuming that your engine is an EP3C, F9 is an engine ECU fuse (15A) and only feeds the engine ECU (pin6).
Yes, You are right. I came to a similar conclusion
