CORRECT AERIAL/ANTENNA FOR MY MK2 CITROEN DISPATCH VAN
mSmerd
Unread post by mSmerd »
Hello everyone, this is for those needy techies among you. I have and early mark 2 Citroen Dispatch Van on a 07 plate. It was fitted with a navigation screen radio/cd player set up which i am told is quite rare. See attachment
The radio has never (since I have had it) had very good reception so when the aerial broke off I decided to get a new aerial fitted. This was the one fitted
It looked like the aerial fitted to the mark 3 Dispatch so I bought a 2nd hand one, see attached
The fitter said it was the wrong one.
Please can you tell me wether a. The correct aerial was fitted in first place or b. Which is the correct aerial for this radio/cd player/ screen set up. PLEASE HELP me find the correct aerial for this navigation screen radio/cd player set up. Thankyou
x 8084
Re: CORRECT AERIAL/ANTENNA FOR MY MK2 CITROEN DISPATCH VAN
Unfortunately we are currently without access to the Stellantis parts database so unable to answer your query. However there are members with access and hopefully one of them will see your post and help out. :)
mSmerd
Thankyou!
And I meant nerdy techies not needy techies!😂
x 1938
Unread post by Paul-R »
Same thing, surely?
mSmerd
I wish someone would give an educated and right answer...
PaulC5
x 675
Unread post by PaulC5 »
I suspect you need somebody with access to Citroen parts diagrams which this site does not have. You might need to visit a dealer parts department.
x 1938
mSmerd wrote: 21 Aug 2025, 14:08 Image
What is the number on the sticker with the bar code?
mSmerd
Bar code is just a tape measure holding the aerial base in the right position for the photo
