Sensors
Nigel Walsh
Sensors
Unread post by Nigel Walsh »
Hi can anyone tell me were the reverse sensor ecu is on my citroen dispatch 16cc jumpy thanks.
x 8144
Re: Sensors
Are you referring to the rear parking sensors? :)
Nigel Walsh
Yes sorry it the reverse sensors ecu just need to check it but I can't find it.
x 8144
Re: Sensors
The link below shows you what the unit looks like, they are usually mounted at the back of the vehicle near a wheelarch or inside a light cluster housing, unfortunately we don't have access to the Stellantis database for schematic diagrams at the moment but hopefully a member who has access may help you out: https://www.ebay.co.uk/itm/167385813927 ... olid=10050 :)
Nigel Walsh
Re: Sensors
Thanks I will have a look tomorrow 😀
Biff1612
Re: Sensors
Unread post by Biff1612 »
if you remove a dpf sensor for deep clean does it need reprograming
x 1941
Re: Sensors
Unread post by Paul-R »
Yes, you have to tell the car that a new DPF has been fitted. You'll need a high end diagnostic machine, preferably Diagbox.
Have you checked the Eolys level as well?
