Hi, I have a 206 1.4 petrol manual 2005 which I'm changing the clutch on.
I'm reassembling after fitting the new clutch - got as far as reattaching the gearbox, gear link rods, clutch cable, starter motor, engine mounting.
So drive shafts are still out, no gearbox oil or electrics yet.
The clutch pedal seems to behave OK now, but...I can shift the gearstick between all the gears easily without using the clutch.
Is that normal at this stage? Pardon the novice question, I'm a DIYer not a mechanic!
I'm loath to continue reassembling if I've messed something up already.
Clutch reassembly
Oldpug
- x 94
Re: Clutch reassembly
Read all the replies on your same topic on the Peugeot Forum, and don’t worry.
The only time to find out that you have done everything correctly, is when you start the engine, dip the clutch, select the gears. Then go for a road test.
