Fuse 11 mk2 2.0hdi 2008 dispatch
Mick c
- x 4
Hi all , I don't have power to this fuse after checking all fuses under bonnet. Fuse number 11 .Could anyone please let me know what this fuse feeds and what rating it should be ?. Does this wiring have a dual use ?. Tia
- x 8145
Re: Fuse 11 mk2 2.0hdi 2008 dispatch
This should help, it says 2006 at the top but the next option is 2009 so this should be correct for your van: https://www.startmycar.com/gb/citroen/d ... sebox/2006
- x 1472
It may be that F11 only receives power when the engine is running.
Mick c
- x 4
Hi thanks for the replies. The link helped a dual I've saved for future reference. I think your right about the f11 only showing power when running as it always worked. Thanks again fellas .
