2011 207 1.6
roscoe62
2011 207 1.6
have changed the clutch on my 207 everything fitted as expected but when i put it in gear the wheels are not moving, it goes into all gears properly with or without engine running any advice please
roscoe62
Re: 2011 207 1.6
update more info. can start car and put it in gear without using clutch nothing canges. slave cylinder is moving the fork. i have it up on jack stands with wheels of, no wierd sounds. hopefully its not the clutch kit i replacedroscoe62 wrote: 16 Aug 2025, 13:07 have changed the clutch on my 207 everything fitted as expected but when i put it in gear the wheels are not moving, it goes into all gears properly with or without engine running any advice please
Onlinemyglaren
- x 5672
Re: 2011 207 1.6
It seems to point to the clutch being incorrectly installed, assuming that it is the correct kit.
roscoe62
Re: 2011 207 1.6
got the kit from ebay gave my details and stated it fits my vehicle. now in process of removing gearbox again . apparently practice makes perfectmyglaren wrote: 16 Aug 2025, 13:50 It seems to point to the clutch being incorrectly installed, assuming that it is the correct kit.
- x 1489
Re: 2011 207 1.6
It always worth a check that the driven plat fits correctly on the input splines before fitting the clutch / putting the gearbox back...I imagine you are going to find the hole is too big.
Onlinemyglaren
- x 5672
Re: 2011 207 1.6
I was thinking along the lines of the release bearing not being fitted correctly but it is over thirty years since I last fitted a clutch (all went well with it and the others, just something I heard mentioned).
roscoe62
Re: 2011 207 1.6
i have now removed it and it fits the gearbox splines perfectlyRichardW wrote: 16 Aug 2025, 18:37 It always worth a check that the driven plat fits correctly on the input splines before fitting the clutch / putting the gearbox back...I imagine you are going to find the hole is too big.
- x 1489
Re: 2011 207 1.6
Dunno then! Does the cover plate clamp up the driven plate when fitted to the flywheel? Got the gear cables fitted properly?
roscoe62
Re: 2011 207 1.6
gear cables all good, clutch plate has a little bit of movement when bolted. i matched it with the old clutch and it looks the same. i have put it back together and same result. the old one was a LUK clutch, the new one is a Borg & Beck Clutch Kit. monday will get a new LUK kit and see if that works. appreciate all responsesRichardW wrote: 16 Aug 2025, 21:12 Dunno then! Does the cover plate clamp up the driven plate when fitted to the flywheel? Got the gear cables fitted properly?
- x 8125
Re: 2011 207 1.6
Is it possible that the release bearing fork is installed backwards eg so that its natural curve is outwards instead of inwards and hence not pushing driven plate far enough?
Vic Evans
- x 175
Re: 2011 207 1.6
Surely the clutch friction plate should have absolutely no movement when the cover plate is bolted up.roscoe62 wrote: 16 Aug 2025, 23:59gear cables all good, clutch plate has a little bit of movement when bolted. i matched it with the old clutch and it looks the same. i have put it back together and same result. the old one was a LUK clutch, the new one is a Borg & Beck Clutch Kit. monday will get a new LUK kit and see if that works. appreciate all responsesRichardW wrote: 16 Aug 2025, 21:12 Dunno then! Does the cover plate clamp up the driven plate when fitted to the flywheel? Got the gear cables fitted properly?
Engine drives flywheel, flywheel drives friction & cover plate assy, friction & cover plate assy. drives splined input shaft to gearbox. Obvious I know but ......
- x 8125
Re: 2011 207 1.6
To clarify my meaning following Vic's description, if the fork and bearing are holding the driven plate slightly off the clutch cover all the time then you will not get drive at all, hence a reversed curve in the fork possible?mickthemaverick wrote: 17 Aug 2025, 11:00 Is it possible that the release bearing fork is installed backwards eg so that its natural curve is outwards instead of inwards and hence not pushing driven plate far enough?![]()
PS or maybe an overthick, ie wrong, release bearing?
PaulC5
- x 690
Re: 2011 207 1.6
Sounds as if the clutch plate is not contacting the flywheel which could mean the plate is not thick enough, the cover is not pressing the plate against the flywheel, the flywheel is worn out. So one or all of these could be at fault or the suggestions of mickthemaverick.
