HI Everyone, i have an issue with my van. it was parked and the alarm was going off, i have disconnected the battery to stop it, i have connected the battery and then it was all dead. No power to the dashboard, no lights, nothing at all. the only light that comes on is the one for manual to the gearbox. any clues ? i have cheched all fuses, i have checked the battery management system. it doesnt connect to an odb reader either, it has power to the port but is not actually connecting.
any tips will be much apreciated.
Kind regards
Catalin
Citroen Dispatch 2.0 Automatic
- x 8149
Re: Citroen Dispatch 2.0 Automatic
You need to be sure the battery is healthy and do a BSI reset following this procedure. The last thing in the procedure is to test it by starting the engine, so go through that and then post up your findings.
basscata
I can not open any windows or light or anything at all. Battery is healthy, i have tried even a different one and still nothing. Theres no power coming to any lights, dashboard, wipers, ac etc.
