Drivers seat height adjustment
TallPaul73
x 7
Unread post by TallPaul73 »
Hi all. I've noticed recently that after I've set my drivers seat height that withing a day or 2 I'm having to set it again as it has dropped... any idea how to fix this?
x 8166
Re: Drivers seat height adjustment
Is it mechanically adjusted or electrical? :)
TallPaul73
x 7
Apologies it's mechanical
x 8166
As it is mechanical it seems likely that you have either a wear problem or a 'something loose or broken' problem.. Unfortunately we don't have access to the Stellantis database at the moment so I have not found a diagram of the mechanics to help. So I would remove the seat from the car and invert it to inspect the cradle and mechanism looking for how it is designeed to hold its height position and the problem may become obvious. Good luck :)
